Stereo Tool 10.21 is released. This is mostly a bug fix release.
Changes:
- Bug fix: Wrong (nonexistent) language selection could cause crashes.
- Bug fix: Console version was reading from wrong settings file by default (~/stereo_tool instead of ~/.stereo_tool.rc on Linux/Mac).
- Bug fix: Omnia.SST licensing was broken in recent versions, possibly other products as well.
- Bug fix: Omnia.SST misbehaved, always tried to apply SSB mode even if that was disabled.
- Bug fix: Command line version could output a message to stdout, which could interfere with streaming input to output in programs like LiquidSoap.
- Bug fix: Generic plugin: Closing the GUI didn't work properly since version 10.00, causing problems with mAirList (and possibly other hosts).
- Bug fix: Generic plugin: API broke due to missing function exports in 10.00. Built-in preset functions are no longer supported, now return false.
- Generic plugin: Removed Full Screen/Height modes.
- Optimized scanning of built-in presets, mainly to speed up startup.
- Optimized scanning of saved presets, mainly to speed up startup.
- Cleaned up GUI code, made it a bit faster and use a bit less memory.
- MicroMPX: Bug fix: Since version 4.2.1 (ST 10.11), decoder could have dropouts every 6h12m46s for certain settings. Was fixed in 4.2.2, but 1 edge case remained.
- MicroMPX: Bug fix: Seting a password, then turning password protection off crashed.
