Would you please check the time interval of listening the "reading metadata from file" and set it more frequent if it's possible?
I am using it to put metadata into RT - the file is at one of the local drive of course - and I experienced that Stereo Tool often but not always needs lots of time (sometimes at least 20(!) seconds) to replace the RT after the file changed. Streaming programs, like Butt or Edcast reacts always less than a second.
Of course I don't mean the RT replacement on the receiver: understand that it needs at least one "full turn" of 2A groups - which needs additional time, depends on the actual number of characters. The delay can be experienced directly at GUI: I/O -> FM MPX settings -> RDS remote control and monitoring window.
Thanks!
It reads the RT text every time the full RT sequence starts again. If you only have a single RT text, you can make it read it faster by putting something like 2s: before it, that would re-read it every 2 seconds. (Probably a bit more than that because transmitting the RT text takes several seconds).
If you have multiple texts, make sure that the one that reads from file is at the start!
