Update: BETA026 is available.
It's based on a new I/O engine
Can you share some insight into the new I/O engine?
It has a number of features that are new:
- Multiple Stereo Tool instances can use it at the same time
- Inputs can be shared between Stereo Tool instances
- An ASIO device can be shared between instances
- Synchronization between sound cards is now part of the framework, before it was specifically built everywhere where it was needed (and not for Input 2 for example, which is why that was missing)
- Backup/adding is now also part of the framework, and no longer handled by Stereo Tool
And things that are planned:
- An output can be sent to multiple sound cards
- We want to use this in plugin versions as well, which will mean that Input 1 would be the plugin input, and Input 2 could be a real sound card. This will make it possible to talk over the audio with The BIMP for example, with Stereo Tool running inside your playout software.
- Giving some input sound cards a delay. This will make it possible to have low latency behavior from some inputs to some outputs even when using multiple sound cards.
- Adding more than 2 input sound cards
- Adding sound cards with more than 2 channels, especially useful for The BIMP.
Not everything is completely supported yet, but we'll add things if they are needed. Most importantly at this point, streaming input and output are not yet supported, and on Linux, Jack is not yet supported.
