Post new topic  Reply to topic  [ 166 posts ]  Go to page Previous 113 14 15 16 17
PostPosted: Mon Aug 05, 2019 3:14 pm
if i switch in the agc of legacy after current agc with different presets no input meters in the agc that move
sometimes it works and sometimes it doesn't work
stereo tool standalone 64 bit 9.34
windows 7 64 bit
Imagegas near my location
Ah. The meters work but your Ratio is set to 1:1. So it does nothing.
PostPosted: Mon Aug 05, 2019 4:56 pm
I'm on vacation at this moment as soon as I get home I will try thank you for your help
Yes it works now
PostPosted: Thu Oct 03, 2019 1:04 pm
Just 15 mins ago i downloaded the Raspberry + Hifiberry image and loaded it into out Pi3 + hifberry, but the pi is just rebooting all the time. It is the MicroMPX_216_Pi234.img.
Is something wrong with the image or is something wrong with our pi?
Regards,
Jack Reitsema
Havenstad.FM
PostPosted: Thu Oct 03, 2019 4:18 pm
Regards,
Jack Reitsema
Havenstad.FM
Please tell us what exactly happens when it reboots. So, when does it happen? How far does it get - does MicroMPX start or don't you even get to that point?
Something might indeed be wrong, we've heard from others that this image works... (and it obviously works here, but the disk image could have an error).
PostPosted: Sat Oct 05, 2019 11:50 am
It might just be easier if i just show you what happens, here is a screenclip of the infinite reboot-loop : https://photos.app.goo.gl/L9wwLrDVv6QDvQFr5
With kind regards,
Jack Reitsema
Havenstad.FM
PostPosted: Sat Oct 05, 2019 2:55 pm
O. That looks weird.
The first iteration I'm guessing it's trying to resize the disk (it should do that). (It should NOT give you that error message in red though!)
But then, it should restart (as it does). And run MicroMPX. But apparently MicroMPX crashes immediately on startup. Without even showing a single message (not even that it's
starting up).
How much experience do you have with Linux? Every 3rd time it reboots it will wait for 1 minute, giving you time to login and change things manually. If you can get in and change the startup script to not reboot, or even just run MicroMPX on the command line and see what error you get, that would help to figure out what's going wrong.
