every time I click the tray icon, Stereo Tool pops up in the background behind all other windows
I see the same thing here, I don't know what changed but this is not intended behavior.
I see. Just thinking, I'm so used to a double-click bringing up a window from a tray icon. Since this is being looked into, would it be possible/reasonable to make a single click on the tray icon bring up the window in the background; and a double click would bring it up in the foreground?
Okay, now I'm noticing that I can't find the window at all sometimes until I "dig" it out from behind a bunch of others. Meaning clicking its normal entry in the taskbar is not possible since the icon doesn't always return after clicking the system tray icon. I haven't found a way to consistently repeat this behavior. But it's with more than one instance of ST, using different executable names.
I originally reinstalled Windows 10x64 onto a new drive to fix hidden taskbar issues. Now I'm having new issues that I don't know are related to my installation of windows or Stereo Tool itself. But since this is the only software with this issue, I'm leaning toward ST; especially within the context of the issue I'm quoting.
