Post new topic  Reply to topic  [ 37 posts ]  Go to page Previous 1 2 3 4
PostPosted: Sun Jan 21, 2024 3:30 pm
yo. i posted this in discord, but I'm putting it here for posterity. the release for 1021 perfect declipper is having issues
there's no button for the GUI in OBS for vst_perfect_declipper_64.dll
and i don't even see it in the plugin list in reaper. the 32 bit one is there though
vst2x32 declipper in reaper:
it's still saying the VST is used without license after i entered my license, only to disappear after unloading and loading plugin again.
the scopes and meter bar aren't appearing either.
and finally (i think) i don't see the checkbox for allowing/disallowing peaks above 0db
edit: since this is referenced in the todo notes, I'm gonna summarize here what i noted in discord:
I think it's time to finalize Perfect Declipper for v10 (by which i mean include the oscilloscopes, the final limiter toggle, Azimuth, Noise Gate, and CPU core settings) and replace the one on the declipper.com site while clarifying it's part of Stereo Tool.
PostPosted: Sun Jan 21, 2024 5:45 pm
Average Joe v0.99.99B.sts
Sure..
Load everything.
Thank you. Uploaded to a soft-AC radio station and listened carefully. I like it. Very much. Thank you
P.S. Why? Some depecrated settings that are not currently used in this peset?
PostPosted: Sun Jan 21, 2024 7:01 pm
Sure..
Load everything.
Because these are stored in the .sts file, these are outdated settings from previous Bojcha presets but are no longer used
PostPosted: Mon Jan 22, 2024 2:17 am
Sure..
Load everything.
well, MB 'mode' used in preset is considered depecrated
PostPosted: Mon Jan 22, 2024 3:34 am
Where is this downloadable? Thanks.
PostPosted: Mon Jan 22, 2024 4:00 am
I was able to find the dsp and vst downloads for declipper plugins. I noticed that the azimuth correction filter has not been included as it was previously. Can we get that re-added, please? It's a great and relevant feature for this plugin and it's been there previously.
Thanks!
PostPosted: Tue Jan 23, 2024 11:48 am
Thanks!
https://www.stereotool.com/download/dsp ... taller.exe
Agreed. Tom thought maybe an old version got cached or something. I asked for clarification in Discord and will post in the next beta thread if I get a reply.
