 Post subject: 7-Elements by GAP
PostPosted: Sun Jan 05, 2014 5:03 am
New Preset for ST v7.40.
- 7 Bands
- All compressors Feed-Forward mode
- Deep and warm Bass
- Presence and delicate high, given an open sound with less fatigue.
Enjoy it! ;)
You can give your opinion.
GAP_7-Elements_v0.1.sts [58.51 KiB]
Downloaded 594 times
by GAP
"Less is More" (Bob Katz)
 Post subject: Re: 7-Elements by GAP
PostPosted: Sun Jan 05, 2014 10:22 am
Another great one. :)
Thank you.
PostPosted: Mon Jan 06, 2014 12:28 am
Thank you.
Thanks. ;)
by GAP
PostPosted: Tue Jan 07, 2014 3:29 pm
Nice preset! You manage to really boost the volume but without causing volume peaks in the song to become muffled and unsatisfying. I also ran it through my test songs which tend to distort on high-volume presets (e.g. "Javyar's Cantina" from "Knights of the Old Republic") and there were no problems there.
PostPosted: Tue Jan 07, 2014 6:17 pm
Thanks for your comments! You described perfectly the goal of the preset! ;)
by GAP
PostPosted: Fri Jan 17, 2014 4:30 am
Second version of the preset, some fixes and refinements, more clearly!
Natural Dynamics Enabled.
I hope you continue enjoying. ;)
GAP_7-Elements_v0.2.sts [58.62 KiB]
Downloaded 376 times
by GAP
PostPosted: Fri Jan 24, 2014 4:49 am
Experimental version for beta 17.
Power Bass and Highs ;)
GAP_7-Elements_v0.3.sts [58.98 KiB]
Downloaded 355 times
by GAP
PostPosted: Fri Jan 24, 2014 5:19 pm
I wonder; what exactly does "Power" bass and highs actually add? In other words, is it just an additional equalizer or does it do something different to make the bass and highs come through clearer? Just wondered the impact on your plugin as I had trouble really noticing the difference between this and the previous version (I do have Beta 17 installed).
PostPosted: Fri Jan 24, 2014 9:20 pm
I have tried to reproduce the same sound , using Power Bass and Highs instead of EQ . As you can see the EQ , is disabled.
This is not to say that Power Bass and Highs , replace the EQ , but for what I use it if I can replace it. Mainly increase the frequencies I want you to excel in the MB and not modify the rest . These are mainly Bass and Highs .
The difference is that when using the EQ , gain is fixed and the differences in levels of bass and highs are absovidas track by the MB . This makes if any.
too much bass or highs in the track may notice more compression thereof.
In contrast with Power Bass and Highs , the amount of gain is variable depending on the track , which makes dynamically modify the track as required . This maintains similar levels of compression for all track without too many tracks with bass or highs , louder sound too .
Try being as clear as possible ,
regards ;)
by GAP
PostPosted: Sun Jan 26, 2014 3:52 am
Some fixes in the highs, was very crispy for my taste. :)
GAP_7-Elements_v0.4.sts [58.98 KiB]
Downloaded 431 times
by GAP
