Post new topic  Reply to topic  [ 21 posts ]  Go to page 1 2 3 Next
 Post subject: X-Mas Sensation
PostPosted: Wed Dec 11, 2013 10:06 pm
X-Mas Sensation (web edition)
Derivat of preset i am making last months adapted to be mostly warm but to keep hotness when needed.
Lot of details preserved with maximum consistence RMS level. Relative loud but clipper is avoided as much as possible.
Punch to maxx.
xmass_web_sensation_RC1.sts [61.13 KiB]
Downloaded 740 times
Let me know. :)
Final Version:
xmas_web_sensation_web_final.sts [61.7 KiB]
Downloaded 1009 times
And 2022 version. For FM set HPF to 39Hz.
Xmas Sensation 2022 Bojcha HD.sts [409.3 KiB]
Downloaded 713 times
 Post subject: Re: X-Mas Sensation
PostPosted: Fri Dec 13, 2013 8:57 pm
Bandpass disabled :?:
I think its already tuned so i put it ON ;)
Garbage in is Garbage out !
PostPosted: Tue Dec 17, 2013 8:35 am
There are couple of things I have to say at this point.
For first I really like the calibrations in AGC specially the side-chain equalizer settings (and the one in single-band compressors). That, in my opinion, is the single most important factor that decides the consistency of a preset. I liked the configuration in King's Fire (though not preset's overall sound). The one in this preset is even better. I have been adapting them in my preset.
Second, about this preset - this is truly way forward from your previous attempts. No offence, but I didn't like King's Fire, so I refrained from commenting anything on it. It didn't preserve bass kicks and instead presented a sub-bass rumble and overall dull textured sound. Also made listeners desire for presence of more highs.
This one is different. Strong bass kicks like in Timbaland intro are preserved well. Highs are subjective. Overall a great preset.
Hope you refine it to something even better.
visit website
PostPosted: Tue Dec 17, 2013 1:46 pm
Okey phoenix.. should i change something. Anyway i will post another version later tonight where i added IMD to bass, just slightly, wich gives a bit even stronger bass/kick and taste of "some" box processors, also other small fixes.
PostPosted: Wed Dec 18, 2013 12:50 am
None in particular. It already sounds good. Will wait for the update. For my taste, I backed off couple of dBs - again loudness is subjective, so ...
visit website
PostPosted: Sat Dec 21, 2013 9:08 pm
Updated to Final.
PostPosted: Sat Dec 21, 2013 9:12 pm
Nice my Balkan processing friend :lol:
PostPosted: Mon Dec 23, 2013 11:21 am
Hi all I am new to Stereo Tool
I have started to test with it in a chain with breakaway broadcast and edcast
I have used this new Settings Xmas and set breakaway on just LR at minus 3 db and level Final drive minus 1 and output 12db protection
Have a listen see if im miles away or actuall not bad?
Its Old Skool Hardcore and Jungle so not the best recordings please leave comments
http://www.danceradiouk.com/danceukradio
http://tunein.com/radio/Dance-Uk-at-dan ... k-s143250/
http://uk2.internet-radio.com:30252/index.html
Many Thanks
Matt
PostPosted: Mon Dec 23, 2013 11:57 am
Please use only Stereotool and Edcast.
PostPosted: Mon Dec 23, 2013 12:07 pm
Ok some help required then as i added the stereo tool as a dsp plugin via breakaway which also has the edcast plugin and output
I basically need stereotool to pick up my main feed in to the pc from mixer and process and send to edcast?
Help?
Matt
