So, you went even further with stiffling highs in favor of the fundamental male vocal frequency range (100-350Hz, bass, baritones, and low tenor), neglecting all of the harmonics, and neglecting to understand that vocals actually exist across nearly all of the frequency spectrum (100ish to way on up to 16000 or so...the upper end is called "breath" / "air")?
Fundamentally, I think the sound you're wanting is something that is not going to be found being made by audiophiles. You seem to like very, very, very prominent male vocals, with specific focus on the fundamental frequencies. What you also seem to be looking for is a Dolby B and/or Dolby C noise reduction, because of your maximum setting of Noise Gate. Dolby B/C is simply not needed for music today, because it is an analog technology. The technology itself is great and is still of great use for analog recordings. The problem is though, analog recordings are becoming obsolete, as digital recordings are now the norm, thus the technology of Dolby Noise Reduction is being made obsolete by transitioning to digital recordings, which do not have the tape hiss that the Dolby string of technologies (A, B, C, HX, R, S, SR) was designed to help alleviate.
Going back to the male vocal range, the problem is that the funamental male vocal frequencies are at the same frequencies of the first few order harmonics of the kick drum, toms, snares, and the bass guitar. Your attempt at highly boosting the 100-350 range causes boosting of the high RMS power of the kick drum and toms (primarily) and the bass guitar, thus causing the the rest of the percussion to be significantly muted, as well as a muting of vocal harmonics.
I have a similar problem with HypersonicV6, except it is in the female vocal range. It's not always evident. A track that exhibits this is Kelis - Brave, yet Diana Ross - Upside Down, I can't pick out the problem. I think I need changes to the way multiband works in order to address that issue, as I've tried many, many, many things. The male vocal range is something completely controllable though, if one chooses to.
Anyway:
- Hot for Teacher sounds even worse, as David Lee Roth has the capability of reaching high baritone / mid tenor, which you're clamping.
- You're still pouring through a massive amount of RMS through Multiband.
- Comparing V1 to V2 via using the disk writer functionality of Winamp and evaluating the output via TT DR Offline shows you have decreased Dynamic Range of Scorpions "Still Loving You" from 6.9 / 7.0 to 6.4 / 6.5
To reiterate, the previous bundled Base 7 preset had:
Dynamic Range (L/R): 6.9 / 7.0
RMS (L/R): -9.6 / -9.7
This V2 has:
Dynamic Range (L/R): 6.4 / 6.5
RMS (L/R): -9.0 / -9.2
So, what was accomplished with my feedback, as well as my effort, was that:
1) You made it louder.
2) You made it have less Dynamic Range.
Revisiting the RMS through multiband, if I get rid of your singleband compressor, TT-DR shows for Still Loving You:
DR: 1.9 / 2.0
RMS: -4.1 / -4.2
Do you understand how insanely loud that is? One of the loudest recordings ever made, Iggy Pop's 1997 remix of "Raw Power" averages RMS values in that range. All things considered, Still Loving You is a quiet track, so RMS values in the -4 range is no small feat given the track. When I use TT-DR on the unprocessed track I have, RMS is -16 / -16.4 , and you're making it up to -4!
By comparision, HypersonicV6_Web produces RMS of -10.4 / -10.5, when I remove the final limiter and adjust to 0.08 dB of loudness. This means that your multiband RMS level is just over a full 6 decibels louder than mine. 3 dB is considered to be doubling, so you've doubled, and then doubled again, or 4 times louder.
Is this where you say, in a George W. Bush tone, "mission accomplished"?
I spent literally hours of time gradually working on getting the RMS power more in line so that clamping via singleband wasn't needed. I gave up when I realized that it was going to take a major investment, but not until after making it to where I had moved to .65 final limiting verses your .45 singleband compressor / limiter setting. Attached is that effort. Bear in mind that HypersonicV6 is using .80 final limiting volume drop, so I was getting it closer and closer to the same RMS being sent through multiband.
