 Post subject: Sound like bdpstrock
PostPosted: Wed May 10, 2023 6:01 pm
Hello! I apologize for my English, the text was translated through a translator.
Maybe someone knows how to set up the sound, like https://bdpstrock.hu/
According to them, they rebuilt it in the Stereo tool? Thank you!
 Post subject: Re: Sound like bdpstrock
PostPosted: Thu May 11, 2023 12:29 pm
The sound is excellent. When they told you they were using StereoTool you should have asked them which preset they were using. This is probably one of their presets. Maybe ask them which preset they use.
PostPosted: Thu May 11, 2023 1:31 pm
The second question I had was What preset are you using? but there was no answer. It is unlikely that they will reveal the secret of such a sound. There are a lot of people with excellent hearing here on the forum, maybe someone will create the same preset. Because there are not enough presets for rock music. (Sorry again for posting with the help of a translator)
PostPosted: Thu May 11, 2023 1:41 pm
I use the Boycha Dynarider preset. I also play rock and metal music. You can hear what it sounds like by clicking here.
