PostPosted: Wed Jun 24, 2020 6:45 pm
I just made this preset couple months ago to our webradio.
Made it to Stereo Tool 8.30.
Quick, clear sound, perfect for those internet radio stations who use different quality and music genres.
Closer to Omnia or Orban sound? I don't know. More to keep a CD quality with quicker AGC.
My opinion: it is a perfect match with 42Net Radio system.
I hope you will like it!
42Net.sts [213.15 KiB]
Downloaded 1914 times
PostPosted: Sat Jun 27, 2020 7:18 pm
This is great! Thanks for sharing. It doesn't quite pip the "Orban 8600 Impact MX" present (the only really usable preset out there?) but it's really close.
PostPosted: Sun Oct 30, 2022 12:14 pm
tnks for sharing - www.koempel-radio.nl from the dutch with proppfrexx and stereotool.
PostPosted: Tue Nov 01, 2022 3:03 pm
I like this preset. It would be a good idea to build it for the latest version of the tool.
PostPosted: Fri Nov 04, 2022 1:49 pm
Thank you 🙏
PostPosted: Sat Nov 05, 2022 10:17 am
Made this account after lurking these forums for a long time just so I could tell you how much I like this preset.
It sounds absolutely fantastic on my setup. Thanks a lot for sharing!
PostPosted: Thu Mar 02, 2023 6:59 pm
I too have been searching these forums for a while. A long time watcher, first time writer so to speak. This preset sounds really really great. Love it!!
PostPosted: Wed Mar 15, 2023 11:36 pm
Hi!
I just also want to say I really really like this Preset a lot! :)
Any update for the newer versions of Stereo Tool?
PostPosted: Thu Mar 30, 2023 7:03 am
These settings are really good it is just like this setting SoundReturn by GAP V4 only difference is it is 2 to 3 db louder with like 15% treble. For a internet radio being louder might be bad for someone listening with headphones crappy laptop or computer speakers
IMO 2nd best setting I have used SoundReturn by GAP V4 is the best IMO
Phat Beats Radio Playing the best Rap RnB Soul Funk Reggae Chillhop Acid Jazz Triphop Blues from the 70s to early 2000s streaming at 192kbps Opus over 165k tracks in the playlist
PostPosted: Thu Sep 14, 2023 1:14 am
I too am wondering about this.
Would very much like to hear what you could come up with!
No pressure, but if you do find the time and the motivation, I'll be there to check out the result :)!
