 Post subject: VZ40 like
PostPosted: Sun Feb 23, 2020 8:26 pm
Hello,
my new tinker ..
try to get closer to the VZ 40 regiscene (its very compressed sound from the 90s), well known in France.
it comes close and it's pretty good, but it's not Dpr 402 based. be indulgent
give me your opinion
vz40 like .sts [151.34 KiB]
Downloaded 179 times
 Post subject: Re: VZ40 like
PostPosted: Mon Mar 02, 2020 8:35 pm
Hi Rackkam,
thanx for sharing this preset with us.
It sounds awsome!
I tried it with several Supertramp tracks as well as other 90's music and it gives that little extra, wider stereo image, warmer sound.
Lovely.
Though at times the compression 'pumping'-effect is a bit tiring.
With some older material, like from the 60's and 70's this preset emphasizes the worn-out character of some tracks,
so it's less suitable for that.
All 'n' all: keep up the good work!
PostPosted: Sun Mar 08, 2020 5:13 pm
Bonjour,
merci a vous pour ce retour d'opinion !
effectivement le VZ 40 etait un reglage analogique tres rapide !
il pouvait etre fatigant à l'oreille.
Beaucoup de radios utilisaient apres un 8100 A ou un UnitY 2000 de Cutting Edge (viel ancetre des omnia... ) pour le " calmer"
le numerique ne permet pas exactement de faire sonner meme maniere.
essayez d'appliquer un peu de " wideband gate release", qui permettra de rendre le son moins " acide" tout en conservant sa coloration.
