Post new topic  Reply to topic  [ 237 posts ]  Go to page Previous 112 13 14 15 1624 Next
 Post subject: Re: StudioOne HD / FM
PostPosted: Sat Jul 03, 2021 6:01 pm
Thank you
https://fmfeeling.com
PostPosted: Sun Aug 01, 2021 11:01 am
Ah.. you can use latest version.. just go to agc and set "remove remaining peeks above" to 500%. just discovered that last night. bugged.
1. I can't find this value. Where is it located in v.9.70?
2. In v.9.70 inside which version of your preset is being used?
PostPosted: Sun Aug 01, 2021 1:26 pm
AGC > Bands
PostPosted: Wed Aug 18, 2021 11:55 pm
What i can say HD works flawlessly with 9.71B37.
I've thrown stuff at it up down left right front center and have yet to make it fail... (and i have some weired shit in my archives... :roll: )
No matter what i do i can't.
1920s up to today. Works
Classical old and new. Works
a bazillion times recompressed MP3 with just 80kbit... works. Bit muffled but works.
Hands down one of the best presets ever made.
PostPosted: Fri Aug 20, 2021 9:17 am
I agree it is an awesome preset. Thank you Bojcha. Please can somebody modify the preset using the current AGC?
PostPosted: Mon Aug 30, 2021 8:44 pm
Bojcha, did your latest version make it into the latest 9.80 release?
Three Decades of Country!
PostPosted: Mon Aug 30, 2021 10:12 pm
huh, no.. latest is v1.99 atm.. will uplodad it now.
PostPosted: Wed Sep 01, 2021 2:23 am
Forgot to answer this.
There is a reason why i still use old AGC. Ofcourse you are free to use new one especially if you want 3 or 4 bands to be involved. However, This preset is all about "minimal compression" and keeping 'originality', so only MB1 is more than enough to do spectrum leveling. MB2 is only for MB1 protection and to protect bass for Bass Clipper so it never 'overclip'.
So, depending what you want, you probably need "Auto EQ".
PostPosted: Wed Sep 01, 2021 8:00 am
Thank you, very much Bojcha. This preset is the best….
PostPosted: Wed Sep 01, 2021 10:23 am
Thank you Bojcha. Please can you upload the final HD Boost version?
