PostPosted: Thu May 06, 2010 3:24 am
I have created a very simple preset for Stereo Tool 5 that emulates VLevel's default characteristic.
I have played some hundreds tracks - old and new from CD and my DVB MP2 (-3db, -6db, -9db pre-limited by the broadcasters).
This Stereo Tool preset should replace VLevel.
To me VLevel is now obsolete.
There is only one small difference:
The Stereo Tool preset adds a nice fade in characteristic.
But this is only noticeable when you play an extraordinary loud (heavy compressed and limited) song and than start abruptly a new original very quiet (or dynamic) song.
Background information here:
viewtopic.php?p=5105#p5105
Copy this and paste it into an empty .txt file and rename it to VLevel Emu.sts
(I am not sure, but I think the last line has to be empty ! - Hans ?)
[Common]
Pre amplifier=10
Post amplifier=1
Extra loudness=1
Extra loudness - Allow extra highs (advanced)=0
Extra loudness - Punchy=0
Extra loudness - Max Punch peak=0.75
Extra loudness - Deep bass protection - Value=0.638750076
Bass protection - Enabled=1
Bass protection - Two steps=0
Bass protection - Clip level=140
Bass protection - Deep bass boost=0
Bass protection - Raise clip level if highs get above=150
Bass protection - Maximum clip level raise=35
Hard limit output=0
[Noise Gate]
Enabled=0
Difference=0
Noise level=0.5
Relative noise gate level - Band 4=1
Relative noise gate level - Band 5=1
Relative noise gate level - Band 6=1
Relative noise gate level - Band 7=1
[Singleband Compressor]
Enabled=1
Difference=0
Maximum volume=1
Attack speed=0.000001694
Decay speed=0.999000013
Above Top Limiter=0
[Pre Compressor]
Enabled=0
Difference=0
Delay enabled=0
Remove remaining loud peaks=1
Maximum volume - Band 1=34920
Attack speed - Band 1=0.000005
Decay speed - Band 1=0.00025
Dual band=1
Relative expected volume of highs=0.649999976
Remove remaining peaks above (relative to maximum volume)=2
[Multiband Compressor]
Enabled=0
Difference=0
Delay enabled=0
Maximum volume - Band -1=5379
Maximum volume - Band 0=6259.200195313
Maximum volume - Band 1=6748.200195313
Maximum volume - Band 2=6943.799804688
Maximum volume - Band 3=6846
Maximum volume - Band 4=6308.099609375
Maximum volume - Band 5=5672.400390625
Maximum volume - Band 6=4987.799804688
Maximum volume - Band 7=3716.399902344
Maximum volume - Band 8=1564.800048828
Attack speeds linked=1
Attack speed - Band -1=0.00005
Attack speed - Band 0=0.00005
Attack speed - Band 1=0.00005
Attack speed - Band 2=0.00005
Attack speed - Band 3=0.00005
Attack speed - Band 4=0.00005
Attack speed - Band 5=0.00005
Attack speed - Band 6=0.00005
Attack speed - Band 7=0.00005
Attack speed - Band 8=0.00005
Decay speeds linked=1
Decay speed - Band -1=0.0004
Decay speed - Band 0=0.0004
Decay speed - Band 1=0.0004
Decay speed - Band 2=0.0004
Decay speed - Band 3=0.0004
Decay speed - Band 4=0.0004
Decay speed - Band 5=0.0004
Decay speed - Band 6=0.0004
Decay speed - Band 7=0.0004
Decay speed - Band 8=0.0004
Above Top Limiter=0
Clipping enabled=1
Postprocessing enabled=0
Relative clip position - Band -1=3
Relative clip position - Band 0=3
Relative clip position - Band 1=2.5
Relative clip position - Band 2=2
Relative clip position - Band 3=2
Relative clip position - Band 4=2
Relative clip position - Band 5=2
Relative clip position - Band 6=2
Relative clip position - Band 7=2
Relative clip position - Band 8=2
Final limiter value=1
Final limiter decay speed=0.0007
Final limiter clipping=2.5
Equalizer enabled=0
Equalizer position - Band -1=1
Equalizer position - Band 0=1
Equalizer position - Band 1=1
Equalizer position - Band 2=1
Equalizer position - Band 3=1
Equalizer position - Band 4=1
Equalizer position - Band 5=1
Equalizer position - Band 6=1
Equalizer position - Band 7=1
Equalizer position - Band 8=1
[Stereo]
Enabled=2
Stereo AZIMUTH Enabled=0
Stereo Image Enabled=0
Stereo Boost Enabled=0
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=0
AZIMUTH change speed=0
Image phase amplifier=1
Image width amplifier=1
Extra phase shift=0
Mono or stereo only=0
Stereo Boost strength=1
Stereo Boost maximum amplification=3
Stereo Boost multiplier=1
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=0
Lowpass filter=15000
Highpass filter=20
[Bass Boost]
Enabled=0
Strength=1
End lowpass frequency of input filter=250
Start lowpass frequency of output filter=250
End lowpass frequency of output filter=350
Clip level=1.5
Preserve louder peaks=1
Difference=0
[Phase Rotator]
Enabled=0
Start frequency=700
Start speed=1400
Number of rotations=4
Smoothness=0.979999959
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1
Pre-limiter enabled=0
Pre-limiter relative volume=1.75
Reduced CPU processing=0
[FM Transmitter]
Enabled=0
Pre-emphasize=0
Pre-emphasis time=50
Output is pre-emphasized=0
Stereo encoder enabled=0
RDS encoder enabled=0
Pilot signal volume=9
RDS signal volume=4.5
FM overdrive volume=1
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing - http://www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2008 - http://www.stereotool.com
RDS PTY=0
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=0
RDS Music=1
RDS Artificial Head=0
RDS Compressed=1
RDS Dynamic PTY=0
RDS RadioText Enabled=1
RDS ClockTime Enabled=1
FM Transmitter Calibration - Phase shift 20 Hz=0.25
FM Transmitter Calibration - Phase shift 160 Hz=0.25
[Direct soundcard access]
Enabled=0
Device ID=Breakaway Pipeline 1
Volume=1
Buffer size=1
Send to Winamp=Nothing
ASIO Override channel 1=4
ASIO Override channel 2=5
[Low latency output]
Enabled=0
Volume=1
Buffer size=0.079999998
ASIO Override channel 1=2
ASIO Override channel 2=3
