Stereo Tool
Feedback, questions, settings and more...
It is currently Tue Jan 16, 2018 8:46 am
 Post subject: Linux, Jack, Liquidsoap
PostPosted: Sat Feb 06, 2016 10:09 pm
I'm running StereoTool as the commandline tool to process a liquidsoap source, and it's not that easy to achieve nicely... We talked about it by email, this is meant as a follow-up, and a request for others to join in ;)
I asked about having StereoTool command line running like the GUI mode, through JACKD, but without the GUI. Or the GUI to have a NOGUI mode, something like that. Would that be interesting? Possible? ;)
PostPosted: Sun Feb 07, 2016 12:11 am
I suggested something about that before (regarding Liquidsoap + StereoTool). Liquidsoap is great but the built-in audio processing is terrible (sky/nrj functions are just terrible, was the guy deaf?)
Why do you need Jack? Liquidsoap accepts pipes and so does StereoTool. One easy solution would be to integrate them nicely without having to play with named pipes. I agree with you though, it's not easy to integrate Liquidsoap + StereoTool.
I think it's something that should also be submitted to the Liquidsoap GitHub repository (issue/pull request?). Creating a new liquidsoap function would work fine (plugin.stereotool within Source / Sound Processing). In the end, it's just a wrap around StereoTool. I mean, it shouldn't be too hard to implement since StereoTool command-line tool accepts pipes as input/output.
PostPosted: Tue Feb 09, 2016 10:57 pm
The issue with liq is that it has no concept of a "processor", it can decode from a pipe, encode to a pipe, but not easily send to a pipe and get data back. Or at least, so I see it. I've asked about that on their mailing-list. Because of this, I need to use an external encoder, but then must compress directly on the pipe, and thus can not use other encoders afterwards in liq... With jackd, I can output to it, let ST do its magic, and input back in liq from jackd.
btw, there are ways to do better than the provided functions in liq, see this: https://gist.github.com/130db/6001343 but this is obviously offtopic
And this you can leverage ladspa, there are many things you can achieve. But in my experience, nothing as easily tunable & efficient as what ST does.
PostPosted: Wed Feb 10, 2016 12:55 am
That was my understanding as well. An ideal solution would be that we can use pipes "within" Liquidsoap. It would be ideal if we can use them the same way we use audio processing functions. However, I don't think jackd is an elegant solution, it would require adding another layer and depends on Jack.
Yeah. I tried to make a processing chain using ladspa plugin with Liquidsoap. It does sound better than the built-in functions but it's nowhere as close as StereoTool.
PostPosted: Tue Mar 29, 2016 11:05 pm
A possible solution could be:
liquidsoap -> stereotool -> flac encoder -> icecast
and then:
icecast flac stream -> flac decoder -> mp3 encoder -> icecast
icecast flac stream -> flac decoder -> aac encoder -> icecast
etc.
I have something similar running (but without liquidsoap).
PostPosted: Tue May 31, 2016 2:40 am
For those interested, the pipe operator has been recently implemented.
:arrow: http://liquidsoap.fm/doc-svn/reference.html#pipe
PostPosted: Tue May 31, 2016 6:51 pm
Hehe, I was going to post that exact message... cheers :D
PostPosted: Wed Jul 05, 2017 1:58 pm
Does anyone have a working example of using Liquidsoap pipe with ST?
Trying to get it to work and struggling, getting buffer over run and garbled audio.
PostPosted: Wed Jul 05, 2017 4:50 pm
Hello,
Does anyone have any examples of the pipe operator working with stereo tool? Trying to figure it out.
James
PostPosted: Wed Jul 19, 2017 7:41 pm
Here's an exemple:
# Input to Processing
input = radio
# Processing
process = mksafe(pipe(process='/home/path_to_stereotool/stereo_tool_cmd_64 - - -s /home/path_to_stereotool/preset.sts -q -k "<STEREO_TOOL_LICENSE>"', input))
# Processing to Output
output = process
