 Post subject: Why this forum section?
PostPosted: Thu Feb 05, 2015 10:04 pm
I very often receive requests from people who ask me to listen to their stream. Often I don't have time to listen (long enough) to properly comment on the sound, so I decided to open this forum section for it.
PostPosted: Fri Feb 06, 2015 12:20 am
Well if i may be the first, then i will, but before i share my link i will say my station is very much a work in progress so expect a lot of changes throughout time, that being said i am sharing this more for the purpose of musical enjoyment than for technical advice, even though technical advice is certainly welcomed. i am using Stereo Tool as a VST on a centova system i built and the exact same settings on a DSP in Sam Broadcaster.
anyway, here goes
http://37.59.37.139:6456/ this is a server in france at 128Kbps Mp3
i've been told my newest settings sound like an Orban 8100 so i am eager to put them into the auto DJ
PostPosted: Fri Feb 06, 2015 7:57 am
anyway, here goes
Pretty cool station! Doesn't sound squashed, in fact it sounds really dynamic which is what I love to hear! Wouldn't say it's quite Orban 8100 level yet though, you really can't beat the sound of that beast! One thing I'd change is the format. I think 128 AAC would be a better option than 128 MP3 as it doesn't have those yucky artifacts that are added after the conversion process, and it's a more modern codec.
PostPosted: Fri Feb 06, 2015 12:01 pm
no, you should hear it live, that's when it supposedly sounds like the 8100, i'm still working on putting the new setting in my centova library, but thanks. and i would love the idea of AAC but many players out there still don't support it. i started this out as a Second Life station a couple years back and as far as i know that's still incompatible with AAC. but the idea has crossed my mind more than a few times
PostPosted: Wed Feb 18, 2015 4:47 pm
-Edit-
See new Topic: Clear Sound
