PostPosted: Tue May 14, 2019 6:38 pm
Noticed this on 9.23 but it may have been there earlier. When using the stream output (which works well), the FM Pre-Emphasis is applied to the stream output as well. Turning the Pre-Emphasis off removes it from both stream and FM. Perhaps if the Stream Output were fed from the MB output, that might fix it.
PostPosted: Wed May 15, 2019 1:19 pm
PostPosted: Wed May 15, 2019 7:35 pm
Thanks Bojcha.....it never dawned on me to look for the setting under an output other than streaming but it worked and I thank you. I used an unused digital output and it got the job done.
