 Post subject: µMPX decoder setup
PostPosted: Sun Apr 14, 2019 11:50 am
Hi Forums,
I want to evaluate ST as µMPX encoder and a standalone µMPX decoder, currently running on the same machine. I struggle to find the right IP to enter in µMPX decoder. It complains it's not a valid multicast address, whatever I put in. Any pointers?
 Post subject: Re: µMPX decoder setup
PostPosted: Sun Apr 14, 2019 8:01 pm
You enter IP's in the encoder setup, not the decoder. Unless you want the decoder to subscribe to a multicast group. In the µMPX-section of ST you'll find a list to enter IP's into (as you're running locally 127.0.0.1 should do the trick).
PostPosted: Sun Apr 14, 2019 9:36 pm
Thank you for the reply - now it works. Why it didn't on first attempt I don't know. It works though it had still a radom Muticast address in the decoder settings.
PostPosted: Mon Apr 15, 2019 10:13 am
That's the address it subscribes to, if that fails it's still able to receive data on the selected port. However it won't receive multicast traffic obviously.
