PostPosted: Mon Feb 05, 2018 10:41 pm
hello ..
I use 5.8 GHz link between 2 points on the my radio station..
ubiquiti pbe m5 400 I am transferring the voice to the other side with these devices ..
there is a device that gives voice automatically..like IP Audio Encoder for Streaming
for example like BARİX.
can i use it rashberry pi with 192 khz sound card and stereo tool and ubiquiti pbe m5 400..
I want to make a system like barix..
automatically ip convert to audio..
is it possible?
PostPosted: Tue Feb 06, 2018 9:13 am
It's not entirely clear what you need, you want to stream just a voice channel? Then sure, a raspberry pi with a soundcard would work.
PostPosted: Tue Feb 06, 2018 9:47 pm
https://www.bswusa.com/Codecs-DEVA-Broa ... 10695.aspx
rashberrpi Do the same with this device?
PostPosted: Sun Feb 25, 2018 10:56 am
I use http://manpages.ubuntu.com/manpages/xen ... dge.1.html to get audio from one Pi to another via ethernet. The first just captures, the second runs ST and outputs the audio. Works quite well and with low latency. With the ST processing it's about 200 ms. Latency will be a lot less without ST.
On a wireless link you will probably need a bit more buffering to prevent dropouts.
