PostPosted: Mon Oct 12, 2015 8:41 pm
I wanted to buy the "Marian Trace Alpha", for use in FM radio, but I needed to know what is the right motherboard, not to have incompatibility issues. Please help me ?
PostPosted: Tue Oct 13, 2015 4:18 am
It's PCI soundcard so you need at least 1 PCI slot on motherboard.
PostPosted: Tue Oct 13, 2015 10:38 am
Please show an example, because most motherboards are the type PCIe and 64 bit and then are not compatible ...
Thank you
PostPosted: Tue Oct 13, 2015 1:20 pm
Just choose motherboard with PCI and enjoy. I recommend ASUS.
PostPosted: Tue Oct 13, 2015 2:20 pm
Every 2nd, 3rd-gen Intel Core MB or newer with PCI slot will do:
H61, B75, H77, Z77 chipsets and more (Sandy Bridge, Ivy Bridge 1155 socket) or newer LGA 1150 for Haswell/Broadwell, like H81, H87 (Z as well), etc. Prefarably with graphics output from integrated graphics built in the CPU (typically you don't want a graphics card in ST machine). ATX, mATX factor forms.
Example LGA 1155 (harder to find a new one, not used)
https://www.asus.com/Motherboards/B75MPLUS/
http://www.gigabyte.com/products/produc ... id=4150#ov
http://www.gigabyte.com/products/produc ... id=4214#ov (even that small, as long as it has a PCI slot)
Example LGA 1150
http://www.gigabyte.com/products/produc ... id=4664#ov
http://www.gigabyte.com/products/produc ... id=4491#ov
https://www.asus.com/Motherboards/H87MPLUS/
Just to name a few.
Asus, Gigabyte are OK. Don't go for Asrock or MSI ;)
For a cheap machine, get used H61 with PCI slot, and i7-2600 or i5 2500 (K, if you want to overclock) and ready to go (Sandy Bridge, 2-nd gen Core gen is approximately 20-25% slower than Haswell, given the same clock, still more than sufficient).
PostPosted: Wed Oct 14, 2015 10:40 pm
ESU Juli is a great card, available in PCI express and a lot less than the Marian.
PostPosted: Thu Oct 15, 2015 11:41 am
Unfortunately, at least in the US, the Juli@ has been unavailable for months.
