PostPosted: Sun Oct 05, 2014 10:17 pm
Hello everyone,
I'm planning to buy a low power transmitter that would allow for MPX injection directly from ST. I have a tiny one built up from kit design. Works pretty well but the point is that it has no frequency synthesizer. It's fine when receiving with old, full-analog knob-controlled tuners... but is quite problematic with digital tuners that operate on rasters (50, 100 kHz).
Here are my basic requirements:
- frequency synthesizer 87.5-108 MHz, prefarably 50 kHz step (but 100 kHz would be fine too).
- rack mount case
- built-in power supply 230V, 50Hz
- MPX input without any filtering that would interfere with the MPX spectrum
- low power (1W min, or prefarably even lower, up to say... 10-50W max)
- tolerant for temperature and humidity variations if possible (will operate in various conditions)
- should be available in Europe (I'm from Poland)
- price up to 400 Euro, slightly higher if worth it (certainly NOT a "no-name" if possible), lower is always welcome
- warranty
If possible
- internal stereo generator with RDS, but with external MPX-in functionality.
This is not for professional operation (tests only), but compliance with existing international standards is mandatory.
I'm really looking for the best and reliable one I can get for the price.
I would be very grateful for any advice (especially based on user-experience).
Regards,
Slawomir
PostPosted: Mon Oct 06, 2014 1:52 am
BW Broadcast has a 5 watt xmtr you will like a lot.Very clean exciter in it. keep rockin..Also have a 1 watt version.
PostPosted: Tue Oct 07, 2014 7:07 am
Make it two for BW - we use ST into a BW-TX50 and it sounds great!
PostPosted: Tue Oct 07, 2014 4:52 pm
Thank you for your suggestions! I really appreciate that!
I found a local dealer that has offered me the BW-TX5v2. He said that this device would be the best for my needs and indeed it looks like a decent one. BUT... is rather pricey... actually the dealer mentioned 1170 euro, which is beyond my budget :/
And just to mention, I don't need dspx mini and stereo encoder included. Ofcourse - if I could get it for the MUCH lower price, then why not.
What about these?
http://www.pcs-electronics.com/cybermax ... p-216.html
Their tech support said that Cybermax FM+ Model C (CyberMaxFM+ DSP/RDS) might work with external MPX, "but probably not without disturbance", as he put it (though it theoretically shuld work, based on the info from manual http://www.pcs-electronics.com/software ... mv4_en.pdf).
He suggested this one instead:
CyberMAXFM+ 15W v4 (MONO MPX) version (D/E). Looks like the one I would look for, but unfortunately I can't find any feedback on these devices.
Regards,
Slawomir
PostPosted: Tue Oct 07, 2014 8:29 pm
I would shop around ebay,etc and get a name brand well known box. pcs does not impress me, I inquired about their product and NEVER got a email response, and I understand someone paid for a box, sent it back for repair and never heard from them again. I would save my money and get the BW.. Progressive Concepts may have some of the non dsp=x boxes in 1 and 5 watt versions.
http://www.progressive-concepts.com/
PostPosted: Tue Oct 07, 2014 9:50 pm
Thank you! I will save some more money for BW then.
PostPosted: Tue Oct 07, 2014 9:55 pm
Or get some 2nd-hand transmitter. That's how I got mine...
PostPosted: Mon Oct 13, 2014 12:41 pm
Build a great quality transmitter yourselve !
http://dutchrfshop.nl/fm-broadcast/prin ... -1389.html
While you're on it... build an 150W amp along with it :)
http://dutchrfshop.nl/onderdelen-kit-15 ... -1438.html
PostPosted: Thu Oct 16, 2014 10:13 am
...or I will try to modify/ask someone to modify my current transmitter (modifications would include frequency synthesis and pure mpx input, which is possible)
http://old.nowyelektronik.pl/opisy/62046.jpg
It is on BA1404
http://www.eltronix.pl/img/products/3923.pdf
PostPosted: Thu Oct 16, 2014 11:57 am
Or get one of these:
http://www.tugicom.com/fm-exciter/tx180.html
Ready to go.
