 Post subject: rds from text file
PostPosted: Sat Dec 07, 2013 9:40 am
hello
I have a question for you. Is it possible to retrieve the stereo tool from txt file to rds song title and the doer? I would add that the file I generated from the issuance program on the local disk. If so, how? Thank you for your response
 Post subject: Re: rds from text file
PostPosted: Sat Dec 07, 2013 12:52 pm
This is from the Help Menu link above:
Including dynamic texts
Dynamic texts can be used to include all kinds of changing information in your RDS texts. For example the name of the song that's currently playing, the current temperature, the weather forecast, you name it.
Stereo Tool enables you to include this type of data, as long as you can make the text available in a file. If you have that, there are 4 ways of including data from a file into your RDS text:
\R"C:\Filename.txt"
Reads raw (unformatted) text from C:\Filename.txt, converts it to capitals, and inserts it here in the RDS text.
\r"C:\Filename.txt"
Similar to \R, but does not convert the text to capitals. So - if your input file contains lower case characters - chances are that some radios won't display (parts of) the text.
\F"C:\Filename.txt"
Reads formatted text from C:\Filename.txt, converts it to capitals, and parses it as if it were a part of the filled-in RDS text. So any special characters (<, ||, : etc.) are used for formatting.
Only use this if you know what you are doing, unexpected special characters in the file can lead to unexpected behavior.
\f"C:\Filename.txt"
Similar to \F, but does not convert the text to capitals. So - if your input file contains lower case characters - chances are that some radios won't display (parts of) the text.
Unless you are doing special things, you should only need \R.
Example:
POWER-FM/PLAYING/\R"C:\NowPlaying.txt"
Because song names can be long, you'll probably want to use the word wrapping and scrolling trick described above:
6s:POWER-FM/1.5s,1=1s,2..-2=2t,-1=1s:||<NOW PLAYING \R"C:\NowPlaying.txt" ON
PostPosted: Sat Dec 07, 2013 2:21 pm
ok thanks, my song from txt. file read and show on rds. But...
what to do in case the name of the artist is too long and cut my last letter of the name. Is there any way to the long name has been divided into the cage? Something such example: "MARKOWSKA" to cut to the MARK-in the next OWSKA
PostPosted: Sat Dec 07, 2013 3:17 pm
No, sorry. That would require knowledge of language (which is also different for different languages).
PostPosted: Sat Dec 07, 2013 4:53 pm
the idea is to divide the long names of performers. Airomate program has options. I enclose pictures HVZ
http://img811.imageshack.us/img811/8880/v2oa.jpg
PostPosted: Fri Feb 20, 2015 2:42 pm
something that would be helpful for me is to make it replace the hyphen (-) in the song name with a space, i need this because i basically use my shoutcast as a source to feed the transmitter. it's not a big deal, but it would be nice
PostPosted: Fri Sep 25, 2015 9:37 am
hello
i have the same problem here,
i'm am new here, so can you tell me were to put the comands /r.
i found it now.
i have an outher qeustion
the pc whre the music are transmitted, is in a network. so stereo tool is installed on an outher pc.
it seems when i put for example 60s: ExtraFm In Stereo on 96Mhz/playing/\r"//pc_radio-muziek/jazler radiostar 2.8/export/nowonair"
it seem that the file path are to long.
how can i solve that problem.
best rehards roger
cialispascherfr24 pharmacy
PostPosted: Fri Sep 25, 2015 11:39 am
http://help.stereotool.com/7.40/fm_transmitter.shtml , search for "Including dynamic texts".
You just type this where you type your normal RDS texts (PS and RT).
PostPosted: Thu Mar 17, 2016 8:38 pm
I am using "FileWrite" function to write to text file. But dont know how to read from text file. I need to read from a text file like 5th line or 2nd line or 12th line.
Please anyone guide me.
regards
PostPosted: Mon Jun 06, 2016 4:28 pm
Please help me!
How can I send the song name and artist by RDS Radio Text. Using the input stream (via VLC) URL device?
Thanks
Filipe
