I've answered you in an email already but for anyone else reading this:
First, I should warn you that so far I didn't get any positive reactions about improved reception with SSB.
When you run your tests, you should indeed try the multipath clipper or the ITU-1268 clipper modes in areas with difficult reception due to multipath issues. (Easiest way to do this is to login remotely to the processing pc, or use the built-in web server which is somewhat clumsy but should be usable for simple changes like this).
Composite clipper strictness: Higher is better, but with BS412 the effect will be small. Normally the default value (I think it was 12) is just good enough, if you go down further you might get some unwanted effects (although, again, with BS412 I wouldn't expect those to be noticeable at all).
