Hi there,
I am sorry if this has been mentioned before, but as you can guess I am new here and this is my first post. I really need help with this!
I have been using Stereo Tool for around 2 years now, and really like what it does to the music (it makes music a lot more punchy and lively!!). I have recently got the RDS encoder working with my mini FM transmitter, along with the FM composite limiter too.
However, the mini FM transmitter has a built in stereo encoder, along with pre emphasis too, which means I have the FM composite limiter set around 100%, with the Pre Emphasis and the Stereo Encoder set to Off in Stereo Tool. If set it around 102%, the modulation is a lot tighter and isn't over modulated any more, but, because I don't need the stereo encoder on in Stereo Tool, this means the audio goes into mono. Unfortunately I can't switch off the Stereo Encoder or Pre Emphasis in the transmitter, as I would if I could.
So basically is there any way I can achieve tight modulation without using Stereo Tool's built in Stereo Encoder? To stop the audio from over modulating on FM I have to set the audio on the PC very quiet! If I switch on the Stereo Encoder in Stereo Tool, the 2 sort of fight with each other creating a phasey sort of sound.
Do I need to buy the full version of Stereo Tool as I only use the Free home version at the moment?
Thanks for reading
Jack
