yes,
What you need is not less then this:
- PC with music and Player / Automation software
- Mixer, enough will be 4mono and 4stereo channels. But, also depends on what you need.
- Microphone attached properly to mixer, dynamic or condeser. (for condeser your mixer should support 48v phantom - or you can use external power for mike)
- Another PC with Stereo Tool installed
So, Output from mixer (master) send to PC2 analog or digital, depend on mixer outputs and PC2's soundcard input.
Oh, you want all in one PC?
Hi Bojcha..tks for back to my question...
If is possible in one alone PC is preferible for us here in southeast Brasil....
How I make work in one PC ???
My Good... You have solution ???
Thanks..thanks...
