Ok, I think I'm getting crazy. So I've even installed 2 ferrites on both ends of the cable going into the STL.
Same results.
I'm posting screenshots of my analyzer in case you see something I can't see. RDS is enabled on ST.
And here's a screenshot with RDS set to off. There is still something on 57khz.
When I lower my sound out to 0.200 (normally at 0.700) there is still something on 57. The 19k pilot of course is lowered now.
The strange thing happens when I lower the input too much (ST shows activity on input at the first green level)
Update. Phase diff. appears at -52 deg again, after 2 songs played.
I'm sharing my preset as well.
[Common]
CPU usage - Quality (new style)=0.200000003
Latency (samples)=4096
Pre amplifier=10.079999924
Post amplifier=1
Extra loudness=2.200000048
Extra loudness - De-esser limit=65536
Extra loudness - Punchy=-0.149999976
Extra loudness - Max Punch peak=0.800000012
Extra loudness - Deep bass protection - Value=0.636619747
Extra loudness - Reflection strength=0.100000001
Extra loudness - Allow more distortion=0
Extra loudness - Highs burst strength=1
Extra loudness - New Bass Protection - Very deep bass filter frequency 1=150
Extra loudness - New Bass Protection - Very deep bass filter frequency 2=350
Extra loudness - New Bass Protection - Clip very deep bass at=0.899999976
Extra loudness - New Bass Protection - BassMid filter frequency 1=350
Extra loudness - New Bass Protection - BassMid filter frequency 2=750
Extra loudness - New Bass Protection - Clip BassMid at=1
Extra loudness - Voice vibrations - Highs feedback strength=1
Extra loudness - Voice vibrations - Never reduce bass below=0.400000006
Extra loudness - Voice vibrations - Multiply measured vibration level by=0.899999976
Extra loudness - Voice vibrations - Ignore vibration levels below=0.5
Extra loudness - Voice vibrations - Reduce sensitivity for non-constant sounds strength=1
Extra loudness - New Bass Protection - Strict clipping=1
Extra loudness - New Bass Protection - Strict clipping - More strict=0
Extra loudness - New Bass Protection - Strict clipping frequency 1=250
Extra loudness - New Bass Protection - Strict clipping frequency 2=350
Extra loudness - New Bass Protection - Strict clipping - Clip bass at=0.899999976
Extra loudness - New Bass Protection - Strict clipping - Clip Punched bass at=0.949999988
Extra loudness - New Bass Protection - Strict clipping - Never dynamically raise bass level above=1
Extra loudness - Dirty Bass=0
Bass protection - Enabled=1
Bass protection - Two steps=1
Bass protection - Clip level=140
Bass protection - Deep bass boost=60.049999237
Bass protection - Raise clip level if highs get above=110.180000305
Bass protection - Maximum clip level raise=35.88999939
Hard limit output=1
[FM Hiss]
Enabled=0
Difference=0
FM median pos=25
FM measure max multiplier=2
FM reduce=150
FM delay=2.5
FM delay median=7.5
[Noise Gate]
Enabled=1
Difference=0
Noise level=1
Relative noise gate level - Band 4=1
Relative noise gate level - Band 5=1
Relative noise gate level - Band 6=1.247190952
Relative noise gate level - Band 7=1.777777672
[Singleband Compressor]
Enabled=1
Difference=0
Maximum volume=1
Attack speed=0.00009539
Decay speed=0.01706367
Above Top Limiter=0
AGC RMS style Enabled=0
AGC RMS style Target RMS level=25000
AGC RMS style Remove remaining peaks above=1.5
[Pre Compressor]
Enabled=1
Maximum volume - Band 1=45760
Attack speed - Band 1=0.000004457
Attack speed - Band 3=0.000002096
Decay speed - Band 1=0.000249943
Decay speed - Band 3=0.00026822
Dual band=1
Third band=0
Relative expected volume of highs=0.649999976
Relative maximum volume of highs=3
Relative maximum volume of very highs=0.330000013
Remove remaining peaks above (relative to maximum volume)=1.299999952
Enable smoothing=0
Smoothing time=10
Gating level=512
Use ITU-BS.1770=0
Channel separation=0.300000012
Gating based on volume before Pre Amp=1
Lock bass to band 2 strength=0.5
[Multiband Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=5370
Maximum volume - Band 0=6250
Maximum volume - Band 1=6740
Maximum volume - Band 2=6940
Maximum volume - Band 3=6840
Maximum volume - Band 4=6300
Maximum volume - Band 5=5670
Maximum volume - Band 6=4980
Maximum volume - Band 7=3710
Maximum volume - Band 8=1560
Attack speeds linked=0
Attack speed - Band -1=0.000032212
Attack speed - Band 0=0.000032212
Attack speed - Band 1=0.000032212
Attack speed - Band 2=0.000032212
Attack speed - Band 3=0.000034489
Attack speed - Band 4=0.000034489
Attack speed - Band 5=0.000072158
Attack speed - Band 6=0.000096324
Attack speed - Band 7=0.000132422
Attack speed - Band 8=0.000132422
Decay speeds linked=0
Decay speed - Band -1=0.000836979
Decay speed - Band 0=0.000836979
Decay speed - Band 1=0.0010933
Decay speed - Band 2=0.0010933
Decay speed - Band 3=0.0010933
Decay speed - Band 4=0.0010933
Decay speed - Band 5=0.0010933
Decay speed - Band 6=0.0010933
Decay speed - Band 7=0.001244719
Decay speed - Band 8=0.001414664
Above Top Limiter=0.519999981
Clipping enabled=1
Postprocessing enabled=1
Flat frequency response enabled=1
Relative clip position - Band -1=1.89855051
Relative clip position - Band 0=2.278688431
Relative clip position - Band 1=2.225806475
Relative clip position - Band 2=2.174603224
Relative clip position - Band 3=2.03030324
Relative clip position - Band 4=1.985074759
Relative clip position - Band 5=1.941176653
Relative clip position - Band 6=1.739726067
Relative clip position - Band 7=1.631578922
Relative clip position - Band 8=1.597402573
Final limiter value=1
Final limiter decay speed=0.000700178
Final limiter clipping=2.508771658
Channel separation steepness protection enabled=1
Channel separation steepness (maximum artifact strength)=0.300000012
Equalizer enabled=0
Equalizer position - Band -1=1
Equalizer position - Band 0=1
Equalizer position - Band 1=1
Equalizer position - Band 2=1
Equalizer position - Band 3=1
Equalizer position - Band 4=1
Equalizer position - Band 5=1
Equalizer position - Band 6=1
Equalizer position - Band 7=1
Equalizer position - Band 8=1
Center frequency - Band -1=43.06640625
Center frequency - Band 0=86.1328125
Center frequency - Band 1=172.265625
Center frequency - Band 2=344.53125
Center frequency - Band 3=689.0625
Center frequency - Band 4=1378.125
Center frequency - Band 5=2756.25
Center frequency - Band 6=5512.5
Center frequency - Band 7=10000
Center frequency - Band 8=15000
[Stereo]
Enabled=3
Stereo AZIMUTH Enabled=1
Stereo Image Enabled=0
Stereo Boost Enabled=1
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=60.000003815
AZIMUTH change speed=0.200000003
Image phase amplifier=1
Image width amplifier=1
Extra phase shift=0
Mono or stereo only=0
Stereo Boost strength=12
Stereo Boost maximum amplification=2.170000076
Stereo Boost multiplier=1
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Lowpass filter=16500
Highpass filter=32
[Bass Boost]
Enabled=0
Strength=1
End lowpass frequency of input filter=120
Start lowpass frequency of output filter=120
End lowpass frequency of output filter=250
Clip level=1.5
Preserve louder peaks=1
Difference=0
[Phase Rotator]
Enabled=0
Start frequency=700
Start speed=1400
Number of rotations=4
Smoothness=0.980000019
Low latency look back samples=112
Low latency look ahead samples=20
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1
Pre-limiter enabled=1
Pre-limiter relative volume=1.850000024
Reduced CPU processing=0
[FM Transmitter]
Enabled=1
Pre-emphasize=1
Pre-emphasis time=50
Output is pre-emphasized=1
Stereo encoder enabled=1
RDS encoder enabled=1
Pilot signal volume=8
RDS signal volume=4
FM overdrive volume=1.010699987
RDS PS text=-DEEJAY-/89.6/
RDS RadioText text=10:89.6 IOANNINA DEEJAY
RDS PTY=10
RDS PI=4233
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=0
RDS Music=1
RDS Artificial Head=0
RDS Compressed=0
RDS Dynamic PTY=0
RDS RadioText Enabled=1
RDS ClockTime Enabled=1
MPX Oversampling mode=Always
[Lossy compression output optimization]
Enabled=0
Spike Protation pre-emphasis time=15
[Direct soundcard access]
Enabled=1
Device ID=Line 1 (Virtual Audio Cable)
Volume=0.939999998
Buffer size=0.049999997
Send to Winamp=Nothing
ASIO Override channel 1=0
ASIO Override channel 2=1
[Low latency output]
Enabled=0
Volume=1
Buffer size=0.180999994
ASIO Override channel 1=-1
ASIO Override channel 2=-1
[ASIO]
ASIO Enabled=0
Sound card=
[Soundcard - Normal output]
Enabled=1
Device ID=Speakers (2- CMI8738/C3DX PCI A
Volume=1
Buffer size=0.268295079
[Soundcard - Input]
Sample rate=192000
Buffer size=0
ASIO Override channel 1=2
ASIO Override channel 2=3
