PostPosted: Thu May 26, 2011 10:27 am
Hello radio friends,
It is possible to limit the multiplex signal? There is an agreement a peak of the modulated MPX signal to 75 kHz. Optimod can do this as I know... !?
Thank you!
Greetings Simon
PostPosted: Thu May 26, 2011 11:59 am
That's what all the limiting (Final Limiter, Loudness, Composite Limiter) is for. So yes, it can do this - and without adding distortion (the Optimod does cause distortion).
You'll have to make sure though that you send the audio to your transmitter at the correct level, and that no changes in the audio (tilt/volume changes) occur due to bad cables or sound cards.
PostPosted: Thu May 26, 2011 2:15 pm
Thank you!!!!!
So it is possible with this tool and a good feed-control to follow the guidelines. Let's see what Media Broadcast protocol says. :)
Greetings
