Clipper, Thanks for the response. I think that is the way Omnia does it, but Stereotool asks for a multicast address and port in the decoder setup using version 4.1.5.
I can't beleive ST micrompx doesn't work. I just don't know what I'm doing wrong.
I did find out that I was getting a ton of transmission errors using Omnia pc to pc that was due to using Voicemeeter with 'VBAN" turned on. I turned that off and the errors in omnia quit, but it didn't help stereotool. I use Voicemeeter Banana for audio distribution.
Due to the inconsistencies in Win10 drivers with system updates I have had to start using Breakaway lines instead of Vaio. Aux Vaio doesn't seem to be effected as much by the updates. Breakaway lines are configured to use 192k and all win 10 sound input and output are configured to 192k.
