PostPosted: Tue Apr 18, 2023 3:27 pm
What I asked myself is, I use stereo tool in combination with micrompx.
Now I first had stereotool sound card sample rate at 192khz.
But also notice that if the sample rate is set to 44.1 khz, micrompx also works normally and generates a stereo signal with rds.
I thought for the FM transmitter settings that the sound card had to be set to 192khz?
Anton
PostPosted: Fri Apr 28, 2023 3:12 pm
If you're using MicroMPX, you don't need a sound card on the pc that runs Stereo Tool. MicroMPX accepts input at several sample rates, including 192 and 176.4 (which is 4 x 44.1).
PostPosted: Fri Apr 28, 2023 5:15 pm
What is the best setting in stereotool 44,1 kHz or 192 or 176,4?
PostPosted: Thu May 04, 2023 8:29 pm
If you're using MicroMPX? Doesn't matter. Just make sure that Windows doesn't resample anything, if that applies.
