PostPosted: Mon May 31, 2010 8:53 am
hi again , first i like to inform you , i try the s.t. ( stand al. or winamp plug in ) in 3 old p.c.( piii 800 1g ) and i have crashes and freeze .
i try it in P4 WITH 2G and works ok .
now , i like to buy the ULTRAMIZER PRO DSP1400P http://www.behringer.com/EN/Products/DSP1400P.aspx
and i like to now how the connection goes ?
b4 or after the s.t ? or if you now its good prodact ?
thanks again .
Vanilla Radio
Vanilla Coffee & Lounge Bar Greece
manager.vanilla ( @ ) gmail . com
|| http://www.vanilla.gr || http://www.vanillaradio.com || http://www.vanilla-lounge.gr ||
PostPosted: Mon May 31, 2010 2:35 pm
1. Then there must be a bug in the P3 version... Bojcha reported that it's running fine on a P3, but I never tested it myself... Will do that now (and try to find where it crashes).
2. NEVER connect anything (except maybe an MPX clipper) AFTER Stereo Tool. The Stereo Tool MPX output must be broadcast unchanged - except for MPX clipping.
3. I don't know if this device is good or not. It seems to do many of the things that Stereo Tool does too, so don't expect to get a louder sound or anything (you probably cannot combine the two without getting bad quality).
Why do you want to buy this device?
PostPosted: Mon May 31, 2010 3:12 pm
thanks for the ansuer , i like to buy it becose i found it from a friend for 50 euros !!
well the s.t.(late version ) i try it yesterday on a P3 800 with 1g as a stand alown with maya44 esi sound card with nothing else runing and freze and crash . i cant make it to work .
thanks !
Vanilla Radio
