 Post subject: Mono broadcasting?
PostPosted: Thu Nov 09, 2017 6:00 pm
Besides turning off the Stereo encoder... are there any other ways for ST to broadcast in mono? Tips?
 Post subject: Re: Mono broadcasting?
PostPosted: Thu Nov 09, 2017 6:19 pm
Way back in 2012, Hans posted this suggestion to a similar question:
Try this:
- Go to Stereo -> Stereo Image
- Enable it
- Set both Stereo Phase and Stereo Width multipliers to 0.00
Now you get the same audio on left and right. And not only that: Sounds that normally would be lost when you convert to mono (phase cancellation) are still there!
I've used that tip ever since, and it works great for my little femto-powered mono FM.
PostPosted: Fri Nov 10, 2017 7:18 am
Thanks Doc! I'm testing our LPFM again in mono, but putting a little more effort into it. Last try, not much difference... maybe because we are also fighting a distant, co channel full power station.
