PostPosted: Mon Oct 31, 2016 4:31 am
I know the standard FM deviation is 75khz, but what should it be with SSB mode enabled and does it depend on the type of SSB mode?
PostPosted: Mon Oct 31, 2016 9:46 am
Still 75. Nothing is different with that, except how the stereo signal is encoded.
PostPosted: Tue Nov 08, 2016 9:40 pm
I always thought the SSB mode was meant to improve multipath by concentrating more power on the carrier (making it more similar to a mono broadcast).
Without getting too advanced, what is it actually doing to improve multipath, if the deviation is the same?
PostPosted: Tue Nov 08, 2016 11:04 pm
Less very high frequency content. The deviation is the same, but if you look at the RF spectrum display, you'll see that it gets less wide. Mono makes it A LOT less wide.
