PostPosted: Mon Oct 31, 2016 12:30 am
Hello,
I'm doing some experimentation with Stereotool on Linux for a monaural AM transmitter. On the Windows version of Stereotool, there is a setting that allows you to reduce the output level to allow headroom for asymmetrical AM processing. I usually find that in: Configuration -> AM Transmitter -> AM Asymmetry.
Even with "Expert Tweaker" selected, I can't seem to find that on the Linux version. Am I missing it somewhere?
Thanks.
Brian
PostPosted: Mon Oct 31, 2016 12:39 am
Hello,
Thanks.
Brian
I went into to .stereo_tool.rc file and manually edited "Volume reduction for asymmetry headroom" , restarted Stereotool, and the setting now appears.
PostPosted: Mon Oct 31, 2016 9:47 am
Ah. That setting is 'deprecated', you can set it also with the sound card output level. So it's removed in recent versions, unless you have set it on a different setting than the default.
