PostPosted: Sat Apr 30, 2016 5:03 am
Hello Bojcha would like to know how to fix the audio card juli @ xte in ST? What setting should I use if someone can share here I will be grateful
PostPosted: Sun May 01, 2016 12:45 am
I am not sure what need to be fixed?
You mean tilt settings for FM or... ?
PostPosted: Sun May 01, 2016 10:58 pm
Interestingly, I recently found out that for some sound cards, the tilt is *not* affected (as I had always thought) by what's connected to it! Which means that it should be possible to include correction values for several known sound cards!'
PostPosted: Tue May 03, 2016 3:14 am
Bought a Juli @ XTE but looking forum need to fix the audio card to FM there would like to know how to do !?
PostPosted: Tue May 03, 2016 7:31 am
Can you elaborate? What about the potential effects on response from things like the transmitter input impedance and / or connecting cable? Isn't this a factor?
PostPosted: Wed May 04, 2016 10:28 pm
That's what I thought. But apparently at least in *some* cards, the tilt occurs in an earlier stage - and the impedance of what you connect doesn't matter.
PostPosted: Thu May 05, 2016 1:28 am
And that's why i asked for "input tillt". :)
