 Post subject: music stops
PostPosted: Fri Apr 25, 2014 12:26 pm
hi again , i buy a new sound card ESI MAYA44+/ USB , i have the same set up in one more pc but with PCI MAYA 44 and win xp and everything work fine .
well the problem is every 1 or more minutes the music stops for second ! do you know what sould i so ?
win 7 ultimate
intel core 2 quad cpu Q8400 @ 2,66GHZ
4GB / 64 BIT
RADIOBOSS / S.T. 7,4 STAND ALONE or Winamp plug in
p.s. 1 .maybe its not sound card problem because its doing the same and with main sound card and s.t. like a plug in .
2. i already do DPC Latency Checker and i have no red lines only green !
3. before i use to play music with audio 8 / usb from NI with no problems.
4. should i try in ASIO mode ?
thanks in advance
Vanilla Radio
Vanilla Coffee & Lounge Bar Greece
manager.vanilla ( @ ) gmail . com
|| http://www.vanilla.gr || http://www.vanillaradio.com || http://www.vanilla-lounge.gr ||
 Post subject: Re: music stops
PostPosted: Fri Apr 25, 2014 1:45 pm
I need some more info. What seems to happen is that the output buffer 'starves' - it doesn't receive enough data.
That can be due to:
- A too high CPU load. Try lowering the Quality slider, if that helps, that's it
- Difference in sample rate between input and output. This can happen if you use different sound cards, Virtual Audio Cable or a stream to feed Stereo Tool.
PostPosted: Fri Apr 25, 2014 8:06 pm
That can be due to:
its not CPU load and the sample rate its ok , i use the DRW from ESI
I Think the problem its with the drivers of the card or with the power of usb ports !
i play now with main sound card with the s.t. 7.41 and i have no problem so far .
hvz i sent you a pm to fb.
Vanilla Radio
