PostPosted: Sat May 11, 2024 6:34 am
PreSouns 26C and MOTU M2/M4 have DC Coupled outputs (some reviews online says this, Can't confirm)
But what about frequency response? anyone running stereotool with these cards can confirm the linearity?
Need Help? Call me, I can help you have a better sound with your actual audio processor, Analog? Unknown Brand? No Problem At All!
PostPosted: Mon May 20, 2024 8:38 pm
I have MOTU M4. Low frequencies are OK, but on highs it is NOT phase-linear. Pira P275 analyzer shows RDS phase shift -32 degrees. It is not acceptable and not correctable by ST software for now.
Also tested Steinberg UR22C and ESI UGM192, they have the same problem, but phase shift is sightly smaller.
For now the only phase-linear USB sound card I tested is old E-MU 0204. Yes is has issues on lows, but it can be easy corrected by ST Tilt correction. At 57 kHz is has 0.85dB drop, but it also can be corrected.
PostPosted: Mon May 20, 2024 10:27 pm
Posted this one a couple of times earlier, but nobody seems to bother. It's really perfect (and waaayy cheaper) and outperforms anything else for MPX-output that I have seen to date.
https://imgur.com/a/2gBn4Vz
USB Realtek ALC4042, DC-coupled output, linear up to 80 kHz (possibly even higher as it can do up to 384 kpbs), SNR 100 dB, cost only € 15 or so. I tried new ST RDS2-support and works like a charm too.
PostPosted: Tue May 21, 2024 3:33 am
Where do I buy it? Please, I can't find it... Thank you...
PostPosted: Tue May 21, 2024 8:49 am
the link you provided to buy is not available please share some alternative
PostPosted: Tue May 21, 2024 9:15 am
That was not a link to buy, it was a picture that I took from the PCB inside. I had opened it to confirm that it actually contains the ALC4042 and to solder in some RF-filtering at the output.
As I had pointed out in some other posts, you should be able to buy here: https://www.onlinekabelshop.nl/nedis-us ... ief-h.html
PostPosted: Tue May 21, 2024 3:30 pm
Thanks for the information, regards...
PostPosted: Tue May 21, 2024 7:49 pm
I can only find this Realtek Digital Audio ALC4050 PCM, available to buy and for my country, could I use it, do you think it would work for me like the ALC4042 chip that you recommend? Thank you...
PostPosted: Tue May 21, 2024 8:04 pm
According to this ALC4050 datasheet that should work just as well, as it seems to have the same relevant specs.
