Does it play via VLC reliably? Every time i tried using the external stream input after some hours of playing it stutters and it need completely restarting stereo tool to work again.. are you using windows?
Sorry, I though I'd answered this, though appears not. Weird.
Anywho, seems to work fine here.
We use VLC to stream to the TX PC via ST using the libVLC input. There is a virtual cable from the main PC sound card that interfaces with VLC allowing it to stream content to the TX PC.
I hope that makes sense.
Cheers,
Baldrick
