So I tried with a third pc running latest windows version with a Julia xte.
I tried getting the input from Streaming via vlc (internal setting in ST) and the output was analog. Everything worked fine. I said ok let’s turn the output, to digital now. When I turned digital on it worked for 3 hours straight and it happened again. Squeaky sounds like setting wrong sample rate and it only worked again when I turned ST off and on again. As I got so frustrated I currently only use pc’s internal sound card with mehh sound but, i want to find out what’s causing the problem..
Something’s wrong with digital + latest drivers because I have tried reverting to older windows and it didn’t work. Today I am gonna try reverting back to windows 7. I am trying it all
It seems like Julia changes sample rate randomly and I have to reopen ST to make it come back to life. I have tried setting sample rate from windows it but didn’t work.
Very strange. Did you try to set both sides to INTernal? Sounds strange but try. I have one point where i have Hardware unit Digital output that was making strange problems with Juli@. I set bot sides to INT and fixed samplerates and since then that connection just works.
