PostPosted: Fri Jan 21, 2022 10:07 pm
I have tried several solutions, including Behringer UMC202HD, but these don't come even close to the result I got using an extreme cheap USB - 3.5 mm headphone adapter, based on the Realtek ALC4042 DAC.
I determined flat frequency response up to almost 80 kHz, no phase error issues, SN ratio 100 dB.
If you can live without ASIO (or maybe even possible with ASIO4ALL) this works just plain perfectly!
I used this particular product:
https://www.onlinekabelshop.nl/nedis-us ... 0-15-meter
PostPosted: Sun Mar 13, 2022 5:14 pm
Hello. Please confirm me. Can you get an MPX signal with that adapter?
PostPosted: Wed May 18, 2022 7:10 pm
Yes, of course. As I said, flat up to 80 kHz, no phase error.
