 Post subject: ST and Dante
PostPosted: Tue Nov 17, 2020 4:55 pm
Does anybody use Dante as a StereoTool input?
I've got Dante Virtual Soundcard, Dante Controller, everything is routed properly. I can use Dante signal in DAW on my PC and it works great.
What should I do to use Dante as an input in ST?
 Post subject: Re: ST and Dante
PostPosted: Fri Nov 20, 2020 7:28 pm
If you have a virtual sound card that should work in Stereo Tool as well? So, what's going wrong?
PostPosted: Wed Nov 25, 2020 7:47 pm
Yes, using Dante and ST running on Windows just fine.
Have you set Dante to ASIO mode? If so, you have to enable ASIO in Stereotool as well, then select the correct channels. I'm not sure if Dante ASIO supports multi-client operation, so it may need to stop your DAW while ST is running in vice versa.
