Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
PostPosted: Sat Dec 01, 2018 11:56 am
The problem, the recommended sound cards Martin and Juli@, at this time is very outdated, they can not be bought. :shock:
I see a negative experience on the forum with the cards Creative and Asus.
From the positive experience, except RME 9632 (it is very old and a lot of money!), аnd Realtek - there are no other choices.
There is also a dark horse Behringer 204HD, Asus Xonar Essence - but there is no exact data whether it has problems or not.
I am desperate, I do not know what to choose up to $ 400.
Except RME 9632 - I do not see other candidates. What can you advise from fresh, modern 192 kHz cards?
PostPosted: Mon Dec 03, 2018 12:57 pm
I was searching for a new card also and found this https://www.aliexpress.com/item/ESI-Jul ... 16830.html ESI Juli@ 4-in/4-out PCI Audio Interface with Swappable I/O Socket 2 analog input channels 2 analog output channels. It's under $400.00. May not be any warranty with it tho.
PostPosted: Wed Dec 05, 2018 10:41 pm
These cards, used, can bought at the flea market at half the price ($100+).
But the feature of my organization, the card should be new, in the store, cashless payments. I have already ordered RME 9632 ;)
But, I want to buy another, USB card :roll: . I can not choose anything - or does not meet the requirements, or very expensive.
PostPosted: Wed Dec 19, 2018 10:48 am
Did someone try RME Babyface Pro? it fits for Stereotool?
PostPosted: Sat Feb 16, 2019 10:08 pm
The Marian Trace Alpha can still be purchased here:
https://www.proaudiosolutions.com/Maria ... -alpha.htm
PostPosted: Sun Feb 17, 2019 2:17 pm
Could someone tell if the cheap USB sound interfaces (Behringer, others?) are suitable for FM? And for ASIO? I remember that some model had a design issue where some of the input would leak to output internally. I really need to get a USB soundcard for temporary FM use, since I'll be using a laptop.
PostPosted: Sun Feb 17, 2019 6:14 pm
Stainberg UR22 or Scarlet 2i2 or 2i4, for example.
PostPosted: Sun Feb 17, 2019 6:28 pm
What about the UMC202HD? It's quite cheap, but datasheet states bad numbers for frequency response.. Are they true, or can the output generate RDS?
PostPosted: Sun Feb 17, 2019 6:42 pm
You really need to ask someone who tested it fully. I usually only talk about what was in my hands.
And what "bad numbers for frequency response"?
PostPosted: Sun Feb 17, 2019 7:22 pm
Output side shows 10 Hz – 43 kHz (0 / + 0.3 dB)...
