PostPosted: Tue Jul 31, 2018 6:42 pm
I am looking for a cheap solution to utilize a Raspberri PI with ST for an LPAM processor. The sound card needs to have a line in.
Thanks.
PostPosted: Tue Jul 31, 2018 9:54 pm
I have this one running, very reliable:
http://www.audioinjector.net/rpi-hat
PostPosted: Tue Jul 31, 2018 10:22 pm
Looks like something that is exactly what I am looking for. I have tried a couple of usb cards but I keep getting an error in ST Error opening:Invalid number of channels Is there a way to fix this?
Thanks..
PostPosted: Wed Aug 01, 2018 11:33 am
You're using the ALSA version and connect straight to the device? I use the JACK version which is happy with 2 capture and 2 playback ports.
