Stereo Tool
Feedback, questions, settings and more...
It is currently Sun May 27, 2018 1:18 am
PostPosted: Sun Feb 25, 2018 9:53 pm
hello i have a marian trace alpha and windows 10, runs for 10 minutes then the audio cuts of and i get a blue warning screen windows reboot and everything works again for about 15 minutes, i have the driver version 3.0.8.9
my processor is a intel q8300 with a dell motherboard
the blue screen says stopcode: nmi hardware failure
PostPosted: Mon Mar 26, 2018 6:06 am
This is a classic driver fault symptom. At the risk of pointing out the obvious:
1) Have you double check this procedure: http://www.marian.de/files/trace_alpha/win/readme.htm ?
2) Has a Windows update replaced the driver with a Microsoft generic driver? Check under the legacy control panel, device manager, sound, then click you card and check the driver to see if it is the one you loaded. If driver is generic you will need to reload the Marian driver then use the Group Policy editor to stop Windows replacing the Marian driver in future.
