PostPosted: Mon Oct 09, 2017 8:10 am
Hi all,
asCirrus Logic Sound card has stopped its production is there any other sound card that could work on raspberry pi 3 for multiplex? I have already installed stereo tool at a raspberry with Cirrus Logic audio card and works perfect but i want to have another one ready for backup and not cirrus logic card is out of production....any other working card?
Thanks for your time!
PostPosted: Tue Oct 10, 2017 10:29 am
HifiBerry has multiple models of soundcards for Raspberry Pi. They support 192kHz. We haven't yet tested one ourselves though, so I don't know how good it is. They're not that expensive though, so if you can spare the money you could order one and find out :)
PostPosted: Mon Oct 16, 2017 7:57 pm
Hifiberry unfortunately only does output (unless you get the digital only version). We have ordered and received a PiSound but not yet tested it.
I've heard from others that the Hifiberry is good and very flat.
PostPosted: Tue Oct 17, 2017 10:37 pm
I want to have also input, hifiberry does not have?
PostPosted: Wed Oct 18, 2017 4:01 pm
Cheapest USB sound solution with stereo input is to buy PCM2900 IC and make your own for few USD (if you know how to solder).
Unfortunately it has only <=48kHz output so it is not good for FM usage.
PostPosted: Mon Apr 23, 2018 2:57 pm
Hi All & Hans!
Did you test this sound card? (PiSound) How is it ?
I'm also considering Wolfson Audio.
in fact, I want something with analog input and 192khz output that works well with raspberry& StereoTool.
Thanks!
