Hi khel
Yes it does and that is how I am using it with SAMBC, I have it on the mixer.
From my post, I had made earlier it was a typo
the option (c) should have been the mixer.
(I am gulity of not checking my post)
However, sadly to say the cpu doesnt max out when I have an AGC activated on both player A and B only, the system load is constant at 42-45%. I also set the affinity for SAMBC to the 2nd cpu and hae SAMBC at a 10 priority. I found a great AGC at SpacialAudio for broadcasting and use that for player A and B.
Further, I monitor the system load with a great utility called O&O cleaver cache for any nonmalies.
CPU is 3.2Ghz, my system RAM is 3GB running on XP pro sp3 and a Creative X-fi elite pro sound card. If you like I can provide you with a screen shot by posting it here. I am streaming SAMBC with kernal streaming using an accPlus encoder
My connection is 16mbit and I am contemplating going to 25Mbit which has just become availlable here. I am fortunate that the Spacialnet server is on the same ISP that I have being only on the average 16ms ping time away.
Stereotool has made a tremendous different with the output as heard on the net, I just love this product.
regards
mapleleaf
