I've checked the ST web site, as well as read what you wrote.
Sound quality is set to Medium.
Screen updates are set to slow
Loudness filter has been brought back to 1.25
Processing @ 44.1KHz
None of this made any difference to the CPU load at all.
Oops - that 1.25 is still on the site, but the Loudness value doesn't make a difference anymore in the last few versions. If it's set higher than 1.00, it takes up a lot of CPU power.
Do you need a loud sound? If not, you can also set Loudness to 1.00 and enable "Do not preserve loudness..." on the Final Limiter. And then set the Final Limiter volume low such peaks don't cause a drop in volume. That will really bring the CPU usage down, but the output will be MUCH softer.
Based on my own experiences from some time ago, on a P4 2.4 GHZ with 512 MB memory I could run Stereo Tool with these settings at about 20-30% CPU usage.
Otherwise, try the following:
- Just turn ALL the filters off (press RESET)
- Check the CPU load. I expect it to be very low if only CoolEdit and VAC are running. If not, something else is wrong...
- Then start enabling the filters that you need, and see how much they use.
