 Post subject: VLC not working on 7.72
PostPosted: Wed Sep 16, 2015 7:55 pm
So trying to output with VLC streaming and I'm getting audio on my sound card (not selected) and nothing for VLC streaming.
FM output checked
Stream via VLC checked
VLC SOUT- --sout=#transcode{vcodec=none, acodec=mp3, ab=128, channels=2, samaplerate=44100}: STD{access=http, mux=ogg, dst=http://127.0.0.1:10993/stream.ogg}
Any reason why this wouldn't initiate a stream. I can't seem to connect to the stream at all. The machine this is coming off of is windows 8 with firewall disabled and no other firewall software onboard.
Also trying to use VLC 2.2.0 Weatherwax for opus compatibility.
PostPosted: Wed Sep 16, 2015 9:05 pm
Since you say you're getting output on your sound card: did you select "Use VLC" as the sound card?
