The declipper and Natural Dynamics start calculating when there's enough data available - at latency 4096 that's every time it has received 2048 samples. This calculation takes some time (almost none on modern CPU's, but it can be a lot on older ones). If this time is too long it might block Breakaway which could cause this type of effects.
Possible solutions:
- Increase the latency in Breakaway
- Choose a lower latency in the declipper (standard is 4096, but you could try 2048).
- Get a faster pc...
I don't know how the latency in Breakaway works, you might want to ask that one on the Breakaway forum.
Hello,
...so i change the processor to i5 3470. The computer power runs at 12%, but still have the crarcles below 1024 asio buffer. It can run and sound good 4096 declipper latency only at 1280 asio buffer in breakaway asio control panel through phase linear and not low latency. Thanks.
Best.
