PostPosted: Sat Jun 12, 2010 10:39 am
Hi again, i install the s.t. in a fujitsu Siemens laptop with Intel core duo T 2350 @ 1,87ghrz with 1918 ram and win vista 32-bit.
i have optimize the laptop for better performance and i have the winamp 5,57(latest version) with sqrs output plug in for crosfade.
Everything works normal but when i install the s.t. dsp plug in for winamp version i have freeze and crashes. when i make a restart in the monitor everything going crazy.....i pres Wright click and the laptop opens anything he like several times like folders programs.....
i cant explain can you help me ?
edit 1 : cpu usage goes to 55-60%
total cpu 1917
on cache 1505
free 10
????????????? is that normal ??
edit 2 : i try it with foobar2000 with vac and s.t. stand alone version and again the same problem freeze.
When i uninstall the s.t. everything again is normal.
Vanilla Radio
Vanilla Coffee & Lounge Bar Greece
manager.vanilla ( @ ) gmail . com
|| http://www.vanilla.gr || http://www.vanillaradio.com || http://www.vanilla-lounge.gr ||
PostPosted: Sat Jun 12, 2010 2:58 pm
You said you install StereoTool as Standalone ?
That should work normal, but how you connect winamp or any other player to StereoTool Standalone?
I use VAC, and there is not problem with that.
Problem will occure if you use StereoTool DSP with winamp and SQR crossfader... but with standalone all shuld be ok.
PostPosted: Sat Jun 12, 2010 3:29 pm
You said you install StereoTool as Standalone ? -- I corrected
first i try it as winamp plug in with winamp!! ( i try with deferent version ) and after that ity with foobar and stand alone version ! in my other laptop everything works normal !
Vanilla Radio
PostPosted: Sat Jun 12, 2010 3:44 pm
ΗΙ BOJCHA , i think the only problem is the s.t. because everything works fine with out the s.t. .
its any adjustment that helps s.t. not to eat so many RAM ? the problem is there . or its another lite or older version of s.t. ? maybe this solve the problem but without any discount on sound quality .
Vanilla Cafe & Lounge Bar
Central Square Krestena Elias Greece
(+30 ) 699 789 0 123 || (+30 ) 26250 22408
Vanilla Radio
PostPosted: Sat Jun 12, 2010 11:22 pm
George,
Crashes and freezes are definitely not normal.
I have looked up your processor, and it seems to be very light (speed per core is close to that of a Pentium 4 from 5 or 6 years ago). So it is possible that the CPU load gets high (around 50% would mean that 1 core is fully used); still the audio should play (maybe with hiccups).
About the memory usage (I suppose "total cpu" in your post is total memory?): Stereo Tool shouldn't use much more than about 25 MB. Could you check (assuming that you're using the Winamp plugin):
- The memory usage of Winamp without Stereo Tool (should be around 15 MB - probably more if you use other plugins as well)
- The memory usage of Winamp with Stereo Tool loaded, not playing (should be around 35 MB)
- The memory usage of Winamp with Stereo Tool loaded and playing audio (should be around 40 MB).
More questions:
- Do you get ANY sound out of it at all?
- Are you using Direct Sound Card Access (in the FM window)? If so, what happens if you turn it off?
If the memory issue is not what's causing the issues, what happens if in Stereo Tool you disable everything (enable 'bypass all' in the main window)? If that solves the problem, try what happens if you either enable filters one-by-one, or start with a lower quality setting.
What you're describing (multiple windows being opened etc.) doesn't seem to make any sense at all...... :?
