The belkin does not filter frequencies in any way I've noted. If I turn stereo mode on while having fm broadcasting on in stereo tool, I do get RDS now and then, and the volume jumps up and down alot (probably because of that interference of the two pilot tones?). So I guess the sound is not filtered, and is just broadcasted by the tunecast in 192 khz anyway (weird though).
Can you turn the stereo coder of your transmitter off and use the one in Stereo Tool instead?
That's exactly what I'm doing. If I turn on the pilot, my radio detects it as being stereo without sending a stereo encoded signal at all though, and that introduces a bit of white noise in the background. If I turn on the stereo coded signal then, sound is fine, still more noisy than when the pilot tone is turned off, but a panning test shows that the left and right channels are encoded in the right way...
But still, the output strength of the fm transmitter seems to be limited, since I can only put my sound card to about 10 % of the volume, anything above that starts distorting. And if I use the stereo mode of the fm transmitter (and the normal non-fm output of stereo tool), I can set it to about 30 %. Which I find weird...
Anyway, for my application it's enough, I just wanted to use it for my pc upstairs to play some music to the radio downstairs, and I can even read what's playing without having to run upstairs... so
(I was surprised at the range, but the dc input seems to work as an antenna :p)
